damian_days Posted June 9, 2020 Share Posted June 9, 2020 Anyone ever try using Rocol Fuelseal? Bought a bottle for £18 from plumbing and gas merchants today - going to use it to seal a fuel tap flange that had a minor leak. I looked at Hylomar Blue, which is fuel resistant, but not fuel proof. In fact the technical specs on Hylomar Blue do warn against its use if in permanent contact with petrol. Whereas Rocol Fuelseal states it is designed for this purpose. Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted June 10, 2020 Share Posted June 10, 2020 And you don't want a leaky flange, if it says its for that purpose it should be ok, most on here if the fuel tap is leaking slightly would get a new seal kit and/or new tap and replace the whole unit to cure it as bodging may lead to problems further down the line Quote Link to comment Share on other sites More sharing options...
Old-codger Posted June 10, 2020 Share Posted June 10, 2020 Why not fix it properly and look at why it is leaking if its faulty repair kit or replace the tap. Trust me the last thing you need is leaking fuel on a hot engine. Quote Link to comment Share on other sites More sharing options...
S-Westerly Posted June 10, 2020 Share Posted June 10, 2020 Leaking petrol on a hot engine will give you a whole new insight to the phrase "my ass is on fire". Quote Link to comment Share on other sites More sharing options...
fastbob Posted June 10, 2020 Share Posted June 10, 2020 I would steer clear of any quick fixes that come in a tube or bottle and address the actual problem . Quote Link to comment Share on other sites More sharing options...
CrossbreedCycles Posted August 30, 2020 Share Posted August 30, 2020 Rocol make good products, it's more expensive for reason. If there's an underlying issue then then it still may not work. Quote Link to comment Share on other sites More sharing options...
Mickly Posted August 30, 2020 Share Posted August 30, 2020 Isn’t a leaky flange now known as a WAP ? Quote Link to comment Share on other sites More sharing options...
