shamg Posted August 1, 2020 Share Posted August 1, 2020 Hello, I’ve been trying to get an old ts100 to start and I have no spark. To begin with, I tested the spark plug by holding it on the cylinder head and I had spark, so I was trying to start it by pouring fuel into the cylinder and kicking it. However, after doing this for a while (to no avail) I’ve tested the spark again and it’s not sparking. Any ideas what could’ve happened? I should also add there is no battery hooked up if that makes a difference.Thanks Quote Link to comment Share on other sites More sharing options...
Tiggie Posted August 1, 2020 Share Posted August 1, 2020 Has the plug got wet and fouled? If you had a spark before and now don't it sounds likely. Try taking the plug off and drying the end over a flame Quote Link to comment Share on other sites More sharing options...
shamg Posted August 1, 2020 Author Share Posted August 1, 2020 Has the plug got wet and fouled? If you had a spark before and now don't it sounds likely. Try taking the plug off and drying the end over a flame Doesn’t seem to have worked, tho the plug is quite old I think. Quote Link to comment Share on other sites More sharing options...
shamg Posted August 1, 2020 Author Share Posted August 1, 2020 Could it possibly be due to there being no battery? Would the ignition system need a battery to spark? Quote Link to comment Share on other sites More sharing options...
Guest Swagman Posted August 1, 2020 Share Posted August 1, 2020 It may but depends on type of system try a different spark plug. Quote Link to comment Share on other sites More sharing options...
