argentum40 Posted August 18, 2013 Share Posted August 18, 2013 After any tips or advice on the this issue. Basically the bike starts everytime when cold or warm but when up to temp its a cow to start, it tries but wont catch then for no obvious reason it will just burst into life.. Never had a bike do this before so qbit stumped Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted August 18, 2013 Share Posted August 18, 2013 have you checked the coils to make sure they are not breaking down when hot and once they cool a bit they let it start again,otherwise mixtures could be out could need good service and filters checking Quote Link to comment Share on other sites More sharing options...
Guest Posted August 18, 2013 Share Posted August 18, 2013 compression is worth a check too.Once the engine is upto temp, the cylinder has fully expanded, worn piston rings wont expand enough to comprensate..causing in a very hard to start engine Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted August 19, 2013 Share Posted August 19, 2013 rings worn that much would normally show up in high amounts of oil useage and the good old blue smoke trail under accleration bit like back in the 2 stroke days Quote Link to comment Share on other sites More sharing options...
megawatt Posted August 19, 2013 Share Posted August 19, 2013 Sounds like fuel starvation to me. Quote Link to comment Share on other sites More sharing options...
argentum40 Posted August 19, 2013 Author Share Posted August 19, 2013 Thanks for replies lads... Ok its just been serviced with new plugs, filters and oil, the coils could be a possibilty although they wouldnt cool down much in a couple of minutes i wouldnt have thought but wont rule them out..Plugs are a good colour according to the manual and theres no blue smoke.. Does use abit of oil but not alot.. Fuel starvation is possible as well and the easiest to sort ( i think).. What would you check lads? Quote Link to comment Share on other sites More sharing options...
Fozzie Posted August 19, 2013 Share Posted August 19, 2013 If it's running fine when started it doesn't sound like fuel starvation... When cold the bike usually has the choke on which richens the mixture right up. On an old CBR600F I had, if it was hot, it would struggle to start and need to be left for a few minutes. But this was just because that was how it was... Mechanics even said it might be a bugger as very hot engine vaporises fuel very well... Often too well!I wondered as if you watch a temp gauge on some bikes right after shutting them off, the heat increases often beyond the point of when the fan comes on. Air cooled engines shut off when too hot, as the temps halt operation... Could the same not be said about water cooled bikes if after shutting them off the residual heat in the cylinder caused it to heat up beyond its normal operational temps. Thus meaning it needs a few minutes to cool down? Quote Link to comment Share on other sites More sharing options...
Tankbag Posted August 19, 2013 Share Posted August 19, 2013 Sounds like fuel starvation to me.Alan don't they have a vacuum fed system ? could be a problem with it ? also maybe carb icing ? Quote Link to comment Share on other sites More sharing options...
megawatt Posted August 19, 2013 Share Posted August 19, 2013 Yeah, they all have vacuum operated fuel taps. When I say fuel starvation, I mean not enough fuel being mixed with air in the carbs caused by heat. Didn,t the mk.1 600 have carb heaters? Quote Link to comment Share on other sites More sharing options...
Stu Posted August 20, 2013 Share Posted August 20, 2013 You won't get carb icing in the weather! Fuel evaporation could be a reason though Quote Link to comment Share on other sites More sharing options...
Grumpy Old Git Posted August 20, 2013 Share Posted August 20, 2013 Auto-choke sticking on? Probably not.Fuel evaporation - More than likely. Quote Link to comment Share on other sites More sharing options...
Tankbag Posted August 20, 2013 Share Posted August 20, 2013 You won't get carb icing in the weather! Fuel evaporation could be a reason though Stu did you mean to say, in the hot weather ? I did, the wee sensor on top of the airbox wasn't working so the carb heaters didn't kick in, I had to give it some beans before it happened tbh but then it wouldn't hot start for about 5 or so mins, it was summer too Alan not sure if the mk1 600s had heaters either, my sk1 1200 did but I dunno,,, Quote Link to comment Share on other sites More sharing options...
Stu Posted August 20, 2013 Share Posted August 20, 2013 No I meant this weather Stupid phone Quote Link to comment Share on other sites More sharing options...
GaryJM Posted August 20, 2013 Share Posted August 20, 2013 Didn,t the mk.1 600 have carb heaters?No carb heaters didn't come till the mark 2. Quote Link to comment Share on other sites More sharing options...
