Better headlight bulb
Motorbike related? Can't find what you're looking for below? Then post here!!
Rustydog
Gender: Male
Bike(s): Yamaha YBR Custom
Has liked: 6 times
Been liked: 14 times
Post by Rustydog » Sun Oct 06, 2019 10:09 pm
As a biking newbie I’m trying to get as many miles under my belt as time and weather permit this time of year. I am though seriously enjoying it and despite needing a lot more experience I’m already dreaming about my next bike later on.
However, coming back home tonight I realised how Carp the headlight is. The headlight, main and dipped just doesn’t throw it far enough or bright enough. I think it’s adjusted correctly so I don’t think that’s the problem. Is there simply a better type of bulb I can put in there to improve things at all?. The bike is a YBR Custom 125 and I think the headlight bulb is a ‘regular’ 35w. Thanks for any tips and info.
User avatar
Mississippi Bullfrog
Subscriber
Gender: Male
Bike(s): Honda CBF500 ABS Triumph Bobber
Has liked: 631 times
Been liked: 1746 times
Re: Better headlight bulb
Post by Mississippi Bullfrog » Mon Oct 07, 2019 7:17 am
I believe you will be limited by the loom and headlight construction to the wattage of the original bulb. Some people have tried fitting a halogen bulb which gives marginally better light than the original spec bulb but not a huge improvement.
It might be worth looking at LED auxiliary lights which won't draw much current. I was chatting with a bloke up at the Ponderosa last week who had some cheap LEDs which made dark country lanes more bearable.
Honda CBF500 ABS
Triumph Bobber
User avatar
Lanceautoman
Gender: Male
Bike(s): Honda CB600F Hornet Past: YBR 125
Has liked: 82 times
Been liked: 31 times
Post by Lanceautoman » Mon Oct 07, 2019 9:10 am
I used to have a YBR 125 - not the custom - and had the same issue with poor lighting at night.
I fitted Harley Davidson style Day Maker LED lamp like the one here:-
https://www.amazon.co.uk/Headlight-Davi ... B017B8NHEE
It was superb: Brilliant light output, nice crisp beam pattern and drew less current halogen. You also wont need to replace the bulb again.
Was easy to fit. The only difficult part was getting it to fit in the housing. This required a bit of fiddling to move wires out of the way but it was all worth it.
Current: Honda CB600F Hornet
Past: YBR125
"I like my women like i like my bikes, dirty, naked and with minimal talk (torque)".
Car:
Jaguar XJ6 3.0
Rustydog
Gender: Male
Has liked: 6 times
Post by Rustydog » Mon Oct 07, 2019 9:20 pm
That looks like just the job-thank you for sharing that!.
If I can get it into the existing chrome housing for the headlamp even better, if not it still seems like I’ll have got the sort of headlight I need-cheers :cheers:
Return to “Motorbike Chat”
Who is online
Users browsing this forum: CommonCrawl [Bot], PaperLi [Bot] and 7 guests
